Panasonic DP-C406 Need a HDD
  • Copiersupport
    • Jan 2016
    • 7
    anyone know where I can get a HDD for a Panasonic DP C406.. damn thing is getting stuck while booting up..
  • JVergin
    Service Tech / IT Rep
    • 216
    Re: Panasonic DP-C406 Need a HDD
    I don't remember what the capacity of a C406 HDD is, but I do know that you can buy a standard hard drive of the same capacity and it should work. Just make sure you buy the correct style of HDD. You'll have the look at the connectors, but the C406 either uses SATA for both power and data, or it uses SATA for data and the IDE standard for power.
    • subaro
      • Oct 2010
      • 1273
      Hard Disk Unit
      Capacity 160 GB
      Caution:
      When reinstalling the SATA Harness, take note of the
      connector position. Insert it gently, and do not force the
      connector if it is facing the wrong way, and exercise
      care to prevent the HDD from Shock and Vibration
      damage.
