Panasonic DP-2000 letter tray not installed
  • hoganape
    • Jun 2025
    I'm having an issue with a Panasonic DP-2000. After power on, and after one copy, the display says that the letter tray is not installed. There are trays in the top two spots. The top-most is the letter tray, the next one down is the ledger tray. Can anyone tell me how to properly install the trays? I do have access to the service mode, but I am unfamilliar with all of the menu options.
  • DUKEY
    • Sep 2008
    • 57
    first are you sure it dosen't say add letter or ldr paper? f5-14 and 14 set tray size make sure they are set right
    • The Destroyer
      Road Warrior
      • May 2009
      • 17
      Panasonic Dp-2000 tray problem
      remove tray one and check for a piece of paper in the back, i sometimes find a crunched up piece of paper behind tray in machine blocking the sensor for tray.
