Panasonic DP150FX Refill kit instructions
  • MPM2140
    • Mar 2010
    • 13
    I have a refill that I have to put into the empty cartridge, does anyone have the instructions.
    I bought the refill from Densigraphixs
  • jaybug
    • 25
    take hammer wack hole in toner box. pour in new toner. seal hole with gorilla tape.
    • tseto
      • Jun 2007
      • 60
      panasonic dp150 refilling
      don't be silly!
      remove the screw holding the small green box , remove green box
      there are 2 screw holding the waste toner unit to the toner unit. one was hidding by the green box just removed and one inside the small circular hole beside the green box removed.
      the waste toner unit can now be detached from the toner unit., slide back the waste toner door and empty completely. clean with a vacuum cleaner.
      covered by the waste toner unit is a refill plug, remove and put aside. empty the remainder of the toner from the unit. unless you have refil before with same toner, mixing toner type can cause quality problem. The toner supply by densi is darker then panasonic oem refill toner. The recharge toner from densi for the panafax uf560/880 toner is even better.
      fill unit with the toner supplied and reassemble in reverse order.
      ps. you may want to clean the mag roller and doctor blade wile you have the unit emptied.
      good luck. arn't you glad, you didn't destroy the toner unit ?
      • pana.techn
        PANASONIC SERVICE TECHN
        • Mar 2008
        • 33
        I like Jaybugs answer better LOL
