panasonic dp-1520p
  • jvargas
    • May 2009
    • 44
    panasonic dp-1520p
    Hi, I have one customer with dp-1520p, when you turn on its is ready to copy, but you press the start button, and nothing happen, only a beep, then I went to service mode, in F2 and it work, i can made copies one by one, thanks for help me
  • mojorolla
    The Wolf
    • 2622
    You could have a number button stuck on the op panel. Try putting in 5 and see if the display changes. If not, a button is stuck.
    Can you print anything from F1 or F9 in service mode?
    • jvargas
      • May 2009
      • 44
      yes, I can do that the copier work in service mode F2, in single copy, the start key work great in this mode
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
        Paul@justmanuals.com
        • jvargas
          • May 2009
          • 44
          yes i paid for it but in other place, more cheap, thanks
          • Logged-on
            • Sep 2010
            • 197
            Can't say I've seen this occur before, but to me it sounds like something in your settings has been changed. I would print out the F5/F6 parameters, and check for the "*'s" if you see any it means a setting has been changed, also check your tray settings and obvious things like that. Also if you go into General Settings, you should also be able to print out a list, and you can check to see if the customer possibly changed some setting, maybe set a tray to special paper or something.
            • jvargas
              • May 2009
              • 44
              thanks, the problem gone, the customer is very happy, i reset all, its work
