panasonic dp-4510 (fax to email) problem
  • JOEBOOROCKSYOU
    • Jan 2008
    • 85
    i'm settin up 2 panasonic dp 4510's to a network
    and all is good except i cannot get the machines
    to "fax to e-mail" for me , is there a setup for that, both units have fax boards installed, am i missing something ?? when going to "fax to email" the display says "check your email perimeters", and i can't get past that..
    any help would be apreciated...thanks....
  • fausto1981
    IT Technician
    • Dec 2007
    • 146
    Well my friend, first of all e-mail is an option. print the "Machine Info Page" see if it says "Yes" next to e-mail.
    Then we can go ahead and set it up.
    if it says "Yes"
    press Function
    Fax E-mail Settings
    scroll down to key operator mode enter the password
    Select User Parameters
    and just go through the settings.
    you need the following:
    machine E-mail address, SMTP IP or if you input the DNS settings SMTP Server Name, if the server requires authentication then you would need to enable SMTP authentication in Fax parameters.
    Make sure you have the right port selected by default it should be 25.
    You can also put all the other non inportant stuff like default subject, selectable domains and such.
    Thats it.
    Good Luck!!!
    • JOEBOOROCKSYOU
      • Jan 2008
      • 85
      thanks, i'll check it out...
      • JOEBOOROCKSYOU
        • Jan 2008
        • 85
        ok i tried to print that in keyop mode,
        no where on the page does it state "e-mail " as a title or "yes or no"
        for that matter...
        when i go to set up e-mail , it's all grayed out..
        like i said the units have the fax boards installed , someone told me that there are 2 different fax boards , one that just faxes and the other that does the "fax to e-mail.
        is this true. my other thought is that we need the "scan to file" board also or is that a completely different issue..
        • just a tech
          • Jan 2007
          • 332
          Hey there joeboo.. As far as i can tell, it sounds like ya have your main fax board in place but are wanting to be able to Internet Fax/ E-Mail and also if possible you'd like to netwok scan.. Right?... If that's the case and if memory serves me correctly, you will need the hardware keys installed onto the SC Board.. I'll try to get ya more info. hope it helps..
          • just a tech
            • Jan 2007
            • 332
            Check ya E-Mail bud.. Sent ya a little more info on your fax and scan options..good luck
            • JOEBOOROCKSYOU
              • Jan 2008
              • 85
              thanks guys for all the help,
              i did manage to get ahold of a danf 600 fax/email key.
              and are installing it today, i could use a couple more if anyone has some...
              also some 8 meg memory boards too..
              thanks again...
              joeboo.....
