Failed to register the leading edge when applying for bypass approximately 1 cm. 5-10
  • alex23845
    • Aug 2013
    • 19
    [CQ] Failed to register the leading edge when applying for bypass approximately 1 cm. 5-10
    DP1515. At Panasonic every 5-10 copies strays registration leading edge about 1 cm. Feeding bypass. Has been replaced by roller, moved and lubricated roller clutch bypass tray, replaced the solenoid. There are any thoughts?
