MP C3500/LD435c Firmware
  • dhaffey
    • Aug 2015
    • 8
    Please someone send me the newest firmware for the MP C3500/LD435c. I can't get the copier company to do it and we Have C2500 that work with Server 2012 Scan to Folder working ok. I just want to update it myself!
    Thanks in advance
  • Zaxxon
    • 608
    Re: MP C3500/LD435c Firmware
    As this is a technical forum, I don't believe anyone is willing to provide the firmware to a non tech, cause there is a chance you'll brick your device and that fw update is a tech job.
    Please start you post with brand, model, problem.
    • dhaffey
      • Aug 2015
      • 8
      I'm the IT guy! Network manager for the company.
      • nmfaxman
        • 1702
        Set up scan to FTP. It still goes to a folder.easier than trying to update firmware on a machine you are not trained to work on.
        • dhaffey
          • Aug 2015
          • 8
          Bricks can be rebuilt........They said the same about my phone. Got it back! Said the same about my PC, bought a new BIOS (LOL). Same about my router, there is always ssh and putty!
            • 37513
            You screw-up a firmware update and you are looking at replacing the controller board.
            • logrady2331
              • Feb 2011
              • 301
              As slimslob says, firmware is not something you will get on this forum. It is NOT something that is passed around to non techs and techs alike. Nobody is doubting your technical skills as they are probably a lot better then mine. (IT wise anyways). No offense, it's just that we (as factory trained techs) protect that kind of information from the general public. If you need firmware you will have to call a copier company and pay them for it. It should be relatively inexpensive (hour labor). You are correct in that a firmware upgrade is needed for WIN8/SRVR 2k12. What you probably also need is ALL the firmware upgraded. (About 17 files, depending on the applications installed) Or you could set up scan to e-mail or FTP.
              • dhaffey
                • Aug 2015
                • 8
                Thanks everyone. It was a shot in the dark but I had to try! Copier company has been called and I explained to the techs boss what needed to be done. However, I do like your forum here and, if I ever need help with the ftp to folder, I may just call on you guys.
                Please close thread...
                • rthonpm
                  • Aug 2007
                  • 2858
                  Thanks for being so civil: we get a lot of people coming on the boards asking and not giving anything in return. For FTP issues, as well as details on scan to SMB, check out the Connectivity section. With IT skills more than just copier skills you could likely contribute to the overall knowledge of the group there. I'm in the fortunate position of starting in the copier field and making the move over to full fledged IT support.
                  We're a pretty close bunch and even though copiers are just embedded Unix boxes for the most part, there is an art to things such as firmware that can cause more damage, and expense, if done by the wrong person.
                  Glad to have you here!
                  • dhaffey
                    • Aug 2015
                    • 8
                    Here..... I'll give you a laugh (or educate myself). Tech claimed to update the firmware already.
                    C3500 What is the most recent versions (Please!)
                    Module Name Version Part Number
                    animation 1.00 B2215610A
                    Network Support 5.20 B2215605L
                    Security Module 1.03 --------
                    Fax 03.00.00 B2215602H
                    System/Copy 1.70 B2215601S
                    SD Scanner ap_1.25 B2215604H
                    Web Support 1.09 B2215606G
                    NetworkDocBox 3.03 B2215608K
                    Web Uapl 1.12 B2215609D
                    Fax(option) 03.00.00 B2215903E
                    SD#1 PCL Font 1.00 B7675383
                    SD Printer 1.70 B8375601K
                    PS3emu 1.01 B8395601A
                    PS3 FONT 1.00 G1065932
                    FCU 07.00.00 B7715571E
                    Engine V1.65:01 B2235117S
                    OpePanel 1.15 B2231491B
                    • rthonpm
                      • Aug 2007
                      • 2858
                      That does look pretty much up to date, and there is no firmware update for anything higher than Windows 7/Server 2008 R2 for this model: at least in terms of production firmware. Someone else may be able to confirm whether there is any custom firmware available that your tech may need to use (Ricoh loves hiding those sometimes). However, the C2500 is a sister machine to the C3500 and its firmware updates only bring it up to SMB 2 as well.
                      You don't have any kind of network settings like only allowing NTLMv2 or anything special do you? Same credentials used on both the C2500 and the C3500 to access the scan destination? At this point it sounds like your issue is more configuration related than software related.
                      • sandmanmac
                        • 3981
                        Originally posted by rthonpm
                        \. Someone else may be able to confirm whether there is any custom firmware available that your tech may need to use (Ricoh loves hiding those sometimes). H\
                        That's exactly what's required:
                        You need the custom network Support: B2215605L_LRC0355
                        • dhaffey
                          • Aug 2015
                          • 8
                          New question. I am a sequential guy! Which is newer, C2500 or C3500????
                          • sandmanmac
                            • 3981
                            Same age:
                            C2500 is the 25ppm version. C3500 is 35ppm version.
                            Firmware, and most internal components are NOT the same
                            • rthonpm
                              • Aug 2007
                              • 2858
                              The MP series machines use the naming convention of the first two numbers being the page per minute, and the last digit being the generation, so the MP C3500 is a 35 page per minute colour machine, and the first of its series: the MP C3501 was the successor model. Four digit models are DLT/A3 capable; three digit models only go up to US legal size paper.
