Lanier LD015 error sc322
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    I must be missing something. I was trying to get this machine ready for resale. The prints were washed out. I traced it back to the printhead. Removed it, cleaned the toner out of it and when reinstalled, error sc322. I got another printhead, installed it and same code. Although the odds were against it, I swapped it with another one, and same code. So now it's not the printhead. I swapped the control board. Same error. What can I be missing?
  • totoro
    • 568
    toner bottle not installed to trip laser detect flag
    toner bottle not in machine
    make sure toner bottle is installed correctly
    reinstall toner bottle LD shutter blocks laser till toner is installed
    replace laser assy.
    Totoro
      • 36250
      Re: Lanier LD015 error sc322
      Do you have a toner bottle installed?
      From Goose's Guide:
      B129/B130/B168 SC 322 toner bottle not installed to trip laser detect flag
      B129/B130/B168 SC 322 toner bottle not in machine
      B129/B130/B168 SC 322 make sure toner bottle is installed correctly
      B129/B130/B168 SC 322 reinstall toner bottle LD shutter blocks laser till toner is installed
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        Thanks for the replies, the toner bottle is instaled, that's why I got focused on the laser. I will retrace my steps. I forgot about the funny things this machine will do when toner bottle is missing. I will admit to not checking the manual, mainly because while I was doing this, my laptop was in pieces at one of the IT guys desk. I had dropped it and he was trying to repair my broken fan so I just Googled the code.
        • fixthecopier
          ALIEN OVERLORD
          • 4714
          Problem solved. I feel stupid. The toner was in the whole time. That was the problem. I had to slide the tray out and back in for it to work. About 2 minutes later, another tech walks up and gives me the same advice.
