af 1224 double image
  • srv
    • Aug 2008
    • 82
    Hi there, I have an af 1224 giving a double image but only when copying or printing in colour.On b/w or single colour it is fine.I have replaced the pcu but to no avail.Any ideas on this will be much appreciated.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    A common fault on this model that normally occurs at some point during the machines life span.
    It's the spring clutch in the transport gear box assembly that lowers and highers the transfer belt cleaning unit on the PCU.
    Some people strip and clean the spring clutch.
    Personally I replace the whole transport bracket for peace of mind and to save time as it's not the quickest of jobs getting it out the back of the machine.
    • srv
      • Aug 2008
      • 82
      I tried cleaning the clutch but it didn't work. I think they are going to upgrade now anyway but thanks for your help.
      • FRIDGEMAGNET
        • Aug 2007
        • 377
        I stripped and cleaned one 4 times one day - never again - it doesn't work, the transport bracket needs replacing.
        • srv
          • Aug 2008
          • 82
          That's good to know.I won't bother stripping it down next time {just order a new bracket}.Thanks for your help.
          • bronson_23
            pls try to check the transfer unri cleaning assy
