Aficio MP 171 , Login from panel
  • pinspin
    • Oct 2011
    • 156
    [Misc] Aficio MP 171 , Login from panel
    Hello ! I have several copiers Aficio MP 171 . Some of them require authentication (Login) to change the IP Address through the panel (123/System setting... ), and some are not required. How can I cancel the Login? Thank you.
    5-801 does not help
  • davel
    • Oct 2011
    • 1104
    Re: Aficio MP 171 , Login from panel
    5-801 does not help
    Admin tools but if you have used 5-801 and not backed up NVRAM the device is now a brick.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      If networked, the setting can be changed via WIM.
      It can also be changed using Telnet, but WIM is GUI based and easier.
      • sandmanmac
        • 3981
        What?
        That's not even close to being true!
        While it's done NOTHING to solve the issue at hand, other than resetting auto shut-off to 1 minute, auto duplex by default, wiping the address book, and network settings, not much else has changed.
        • pinspin
          • Oct 2011
          • 156
          I restored non default setting ( 5-990 ) after 5-801 . I did not find this feature ( Login ) in Admin tools (((
            • 37490
            For most Ricoh models:
            1. User Tools
            2. System Settings
            3. Administrator Tools
            4. Administrator Authentication
            Turn off network administrator and machine administrator. May require login in order to change.
            • pinspin
              • Oct 2011
              • 156
              1. User Tools
              2. System Settings
              Thank you my friend !!! It works )))
