SR4020 to a 4030?
  • digicor
    • Jul 2008
    • 1153
    SR4020 to a 4030?
    Can a sr4020 be upgraded to a 4030 by firmware? Ive replaced mpc7500 with a 7501 but the fin was bad, i was trying to use the existing Fin (SR4020)
    just wondering if this is possible thanks
    • 37490
    Re: SR4020 to a 4030?
    Check the point to point wiring diagram and the parts catalog. If the PtoP is the same but b the part number for the PCB is different, yomay have to change the PCB. The problem with the bad Finisher is not the PCB, you have a board.
