Guys, we installed four new machines (MP C2503sp) with fax options but the keypad is not working when FACSIMILE function is used. All four machines are having the same problem. When COPY function is used, the keypad is working. I tested the fax modules to the old MP C2503sp and it was working. I already updated the firmware and performed MEMORY CLEAR (FAX APPLICATION) but still the keypad is not working in FACSIMILE. Any idea how to solve the problem? TIA
FAX PROBLEM (MP C2503SP)
Re: FAX PROBLEM (MP C2503SP)
I had a c5502 that I installed a fax unit on and when trying to select the fax key, nothing would happen. I had to update the LCDC firmware to get it to work. Just a thought.NEVER ASSUME ANYTHING -
Can you see the fax screen, i know when you install the fax you may need to set the quick keys on the left side that say copy print etc for it to work, in user tools there is a quick key set up to assign the keys accordingly. If your able to see the fax screen but the touchscreen is not working then i would reflash the LCDC firmware as suggested above.Comment
I will try this one....just for testing...
System Switch 0A (SP No. 1-101-011)
Dialing on the ten-key pad when the
external telephone is off-hook
0: Disabled 1: Enabled
0: Prevents dialing from the ten-key pad while the
external telephone is off-hook. Use this setting when
the external telephone is not by the machine, or if a
wireless telephone is connected as an external
telephone.
1: The user can dial on the machine's ten-key pad
when the handset is off-hook.Last edited by sharpmind; 02-25-2016, 07:47 PM.Comment
