MPC2800 Can't Print PDF
  • darknet93
    • Nov 2015
    • 89
    i have MPC2800 thath can't print file PDF. other than PDF like word or jpeg don't have any problem.
  • sandmanmac
    • 3981
    Re: MPC2800 Can't Print PDF
    Then you have an MP C2800 that works properly, and either a problem with the PC or the PDF reader program (most likely) you're using
    • rthonpm
      • Aug 2007
      • 2854
      Does the machine refuse to print any PDF, or just specific files? It's possible that there's a security restriction on a particular file that prevents printing it.
      • NeoMatrix
        Senior Tech.
        • 3513
        Do you have a postscript SD/VM card install on the MFD ?
        If so, is it migrated onto the printscan SD/VM card as one VM card without error ?
        Is the above card in the correct SD slot ?
          • 37489
          Can you be a little clearer as to what happens when you try to print a PDF?
          • darknet93
            • Nov 2015
            • 89
            actualy this is what my cust complain to me. because she said that if using the HP printer can print all files include PDF file. only using that mpc2800 can't print PDF
            • darknet93
              • Nov 2015
              • 89
              • darknet93
                • Nov 2015
                • 89
                no that machine does not have any postscript card or VM card. actualy this is what my cust complain to me. because she said that if using the HP printer can print all files include PDF file. only using that mpc2800 can't print PDF
                • darknet93
                  • Nov 2015
                  • 89
                  actualy this is what my cust complain to me. because she said that if using the HP printer can print all files include PDF file. only using that mpc2800 can't print PDF.
                    • 37489
                    Fine but we need to know exactly what happens when she tries to print to the MP C2800. I.e. you need to go there and observe what is happening.
                    • darknet93
                      • Nov 2015
                      • 89
                      the thing is the printer just blinking one time and then nothing came out. i already go there there and take a look. FYI i have try to update the firmware and update the adobe reader to the latest one.
                      • sandmanmac
                        • 3981
                        One specific pdf or all?
                        Have you tried another pc on the network?
                        Have tried printing from your own laptop?
                        Have you tried another pdf reader? Example: Foxit reader?
                        Once again..... If it's printing everything else, it's NOT a machine issue.
                        • SwisSeV
                          • Jan 2016
                          • 307
                          Slimslob is just asking for more information.
                          "Printer blinking one time, nothing came out" isn't much to go on.
                          What's going on with the spooling, job status, what's blinking exactly and so on.
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3944
                            You're not trying to send a PDF directly not using a print driver, per chance?
                            You can do that with the newer models, as there is built in firmware to handle it, but on older models (such as this one) the PostScript option is required.
                            I have one large account that prints from SAP constantly, just LPRing the PDFs, not using a driver. Almost none of their machines have PostScript, and the files print OK. That was not the case with their older machines; they needed the option.
                            • darknet93
                              • Nov 2015
                              • 89
                              Hi,
                              all PDF can't print out.
                              yes i have try my own laptop and still can't print
                              yes i have try other pc on network still can't print out
                              other pdf reader? not yet. and i will try that one.
                              if using other printer machine like HP can print all file and the pdf normaly just this machine
