Hi,
I have n issue with 2 Ricoh (NRG) 161 SPF machines.In the web page after i logged in admin mode and trying to setup scan to folder the menu to make that won't appear .I cannot make scan settings to work with SMB as you can see in the picture bellow.
The machine is updated with the latest firmaware and did all the settings on the machine.
I have also replaced the printer/scanner SD card and nothing changed.
Any help will be much appreciated!
