MP7001 not recognized on network
  • tufbnme
    • 493
    This machine cannot be seen on the network. I have replaced the complete controller assembly and still nothing.
    Checked the onboard NIC, it is "on"
    Any suggestions?
  • LNorris
    • Sep 2008
    • 645
    Re: MP7001 not recognized on network
    can u direct connect from a laptop?
      • 37513
      If you set it to Auto Obtain IP address does it get an IP address? If you unplug the network cable from the 7001 and plug it into your laptop do you get a network connection on your laptop? Has someone turned IEEE 802.1x?
      • keithxxiii
        Just a tech
        • Nov 2014
        • 469
        print the configuration page and make sure that access control is not set
        Aye! Cut the crap
        • MIKON
          • Jul 2015
          • 188
          Check in system setting
          interface settings
          screen 2
          IEEE8021.x authentication or Ethernet is set to inactive.
          • anothertech
            • 1771
            You would think he'd have the courtesy to come back with some answers, but no, he MIA
            • Bantams
              • Jun 2012
              • 603
              Probably not even a SP machine...............
