MP4002 leading image in Duplex mode !
  • GeorgeBest
    • Jul 2009
    • 513
    Hi,
    Problems on adjusting the leading image and side to side image when copying double-sided.
    It happens with the DF but also when putting the original on the glass.
    In both ways the image on the "duplex"side is not aligned, it shifts about +/- 8mm.
    Strange, because when I'm printing double sided, no problems !
    So it can't be the feed of the duplex . . . ..
    Don't what to adjust, tried everything, scanner: SP4008, 4010 and 4011
    and also in DF : 6006, etc . . .
    anyone an idea?
    Thanks in advance
  • techmann
    • May 2016
    • 41
    Re: MP4002 leading image in Duplex mode !
    There is actually a duplex registration adjustment on the main copy screen. Drove me nuts the first time I ran into this. Adjust it and program as defaults, and you should be good.
    • GeorgeBest
      • Jul 2009
      • 513
      you're kiddin'
      not in the SP mode?
      Will check tomorrow
      Thanks!
      • teebee1234
        • Jul 2008
        • 1670
        User tools>copier/doc server settings>edit tab>1 to 2 sided (set to 0.0)
