MPC 3002 Bad Print Quality
  • Roger67
    • Nov 2013
    • 84
    Hello,
    i have a problem with a MPC 3002 during print outputs with higher resolution.
    With 1200 x 1200 dpi the resolution in the black parts of the Pic looks good.
    With 2400 x 600 dpi the resolution in the black parts of the Pic looks bad.
    See att.
    Im using a PCL 6 Driver and the FW: PCL 1.15 / System 2.16 / Engine 1.10:04 / PDF 1.04
    Thanks for help
    Roger
    MPC 3002.pdf
  • TonerMunkeh
    Professional Moron
    • 3869
    Re: MPC 3002 Bad Print Quality
    Bearing in mind you're using an office MFP using the PCL driver and not Postscript, the shift in resolution will cause the machine to use more process black in the image creating your colour differential. You're never going to get a perfect colour match on this machine.
    Anyhoo run line position adjustment, run process control and then ACC it. Make sure all your PM parts are in life.
    On a lighter note, that is some epic sideboob.
    Hit it.
    • Roger67
      • Nov 2013
      • 84
      Using the PS 3 Option,even the Print Quality is much more worst than the Examples with the
      PCL Driver.
      See att.
      PS Driver.pdf
      Printing the same File on a MPC 4503 using the PCL Driver,the Quality is good.
      We almost changed every Board,the Novram etc. in the Defectiv MPC 3002.......
      Now we dont now,what to do !
      Cheers
      Roger
      • TonerMunkeh
        Professional Moron
        • 3869
        Oh hang on, I think I know what's going on here. Print out a printer ACC test pattern. Are the first 8 or 9 sections really pale then the the last 5 or 6 solid as anything?
        Hit it.
        • Roger67
          • Nov 2013
          • 84
          Hmmm,there was something special on my ACC Test Charts........please see the Att.
          ACC.pdf
          Cheers
          Roger
          • TonerMunkeh
            Professional Moron
            • 3869
            Right. Change SP4-010-001 to -2.0mm. Perform a printer application memory clear SP5-801-008. Reboot. Run SP2-111 modes C then A, then ACC it. That should sort it.
            Also see: http://www.copytechnet.com/forums/ri...ght=4502+gamma
            Hit it.
            • Roger67
              • Nov 2013
              • 84
              After adj. the Machine again with your Infos,the Prints aren t looking good.
              See Att.
              PCL 19.7..pdf
              • BLADE
                former propeller tester
                • 478
                reseat controller
                • TonerMunkeh
                  Professional Moron
                  • 3869
                  Okay. It's the ACC that's affecting the copy quality. Run 5-801-008 again and don't ACC the machine.
                  Hit it.
                  • Roger67
                    • Nov 2013
                    • 84
                    Hi Folks,
                    after reseting the SP 1101-4 and a new ACC adj. the Machine runs well !
                    Thanks for your Help
                    Greetings
                    Roger
                    • BLADE
                      • 478
                      Originally posted by Roger67
                      Hi Folks,
                      Greetings
                      Roger
                      good one, where do we get the test chart
                      • stefan1129
                        good morning,
                        i have the same problem..there is a way to reset the controller?
                        Thanks,
                        • stefan1129
                          Using the procedure write by TonerMunkeh print is ok. If the problem reappears, it is possible to reset controller or you need to change controller?
                          Thanks,
