MPC2011 - Print with password
  • AleLeader
    • Oct 2012
    • 29
    I have MPC2011 and i can instruction for put number code when print with PC.
    i want when print document , mpc2011 not print , after put code print .............. if possibile.
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: MPC2011 - Print with password
    Turn on user authentication with user codes and set the restriction for print. Then add users to the address book with a user code for each user....
    Mystic Crystal Revelations
    • AleLeader
      • Oct 2012
      • 29
      Where is found menu ..Turn on user authentication with user codes and set the restriction for print.
        • 8144
        Ricoh User Codes Guide
        Here's the User Codes guide, very useful
        http://www.ricoh.co.nz/support/pdf/U...ONO_ver1.0.pdf
        • AleLeader
          • Oct 2012
          • 29
          but i need when print digit CODES USER
          • AleLeader
            • Oct 2012
            • 29
            ok found ... i think
            https://www.as.uky.edu/tutorials/con...-ricoh-copiers
