MPC 6502 Paper jam in Fusing Unit
  • Roger67
    • Nov 2013
    • 84
    Hello my friends,
    after a wrong operation,we were do a Reset on Adress 5-801-2 (Engine ).
    After that,the Machine right durring Boot up the maschine shows a Paper Jam ( 001/ LeverD2 ) without Paper.
    We took the information on the Sheet witch is in the front Cover witch uncludes
    the Information for the Laser etc. and programmed it.
    We upodadet the Firmware,we changed the Fusing Unit etc and have still the same problem.
    Any one have an Idea ?
    Thanks for help
    Roger
    • 37490
    Re: MPC 6502 Paper jam in Fusing Unit
    You either have a stuck sensor arm in the exit unit or a bad door switch.
    • SRtech
      if you have a back up of NV RAM then restore it, hope it will work fine.
      • M0scb
        • Oct 2012
        • 32
        Have you had to do an NVRAM reset on this device? If so there is a sensor calibration you need to run before the sensors will work. Engine or full reset use SP1134-001 and run. Result is in SP1134-002 should be between 200 and 400.
        • copier tech
          • 8144
          I know this exact issue. You need to change an SP setting, look under mode "fuser entrance sensor" change this to "1" (or if it is 1 change to 0)
          • Roger67
            • Nov 2013
            • 84
            Hi Folks,
            the Info to calibrate the Sensor SP 1134-001 fixed my Problem and i think i dont need to
            backup the NVRAM Data,which i finaly dont have.
            The Machine runs well !
            Thanks for the Help
            Cheers
            Roger
