Ricoh 1018/2018 PCQ
  • copycart
    • May 2009
    • 97
    Ricoh 1018/2018 PCQ
    I have a 2018 that when making copies from the glass, I get a dark sky shot like band on the rear side of the copy. I have seen this problem on the 1018 copiers and have never been able to figure out the cause
    • 37490
    Re: Ricoh 1018/2018 PCQ
    Check the drum. The photo conductive coating could be worn off or the surface could be coated with toner.
    • copyaction
      • Oct 2007
      • 991
      Is it only from the the glass?
      How about when you print a counter sheet or use the adf?
      • Iowatech
        Not a service manager
        • 3930
        Could you share a picture? I don't think I've ever seen that exact problem before. In the mean time, you might want to replace the transfer roller. At least without actual troubleshooting information that's what I'd try next. But that is just an uninformed guess.
        • mongo
          • Jul 2009
          • 55
          Pull the PCU and stretch the springs on the back wall of the machine and clean the contacts on the PCU. That will take care of that 2 inch band if the drum is coating not worn off. Mongo
          • Mark Bbb
            • Jun 2012
            • 1662
            As I understand well, the back side of a single printout is black.
            If this is so => transfer problem
            which can be caused by a bad pcu (worn?) OR a bad transfer roller position or the grounding of it.
            Also if many jams happens the transfer roller get dirty quickly and causing this problem to.
            • mikadonovan
              • May 2008
              • 2931
              It's coming from the transfer roller. You can turn on transfer roller cleaning, but it's been my experience that a developer change is the only remedy for this. Be sure and set developer according to procedure.
              NEVER ASSUME ANYTHING
                • 37490
                My understanding of the term "rear side" refers to the edge of the paper that is to the rear, as opposed to the operator side, as it comes of the paper exit, not the "back" of the sheet of paper.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  In the Dutch (and south Africa) language we say "achterkant" or "verso-zijde" for what is printed on the back of a duplex document. What is (are) the exact term(s) used in the English language?
                  • teebee1234
                    • Jul 2008
                    • 1670
                    If the dark band is only when copying from the glass then another possibility is that the white platen sheet is deformed/rippled or not sitting flush with the scanner surface . It will allow room light through and give you that condition. Would help to post an image and a few more details.
                    • DRichard
                      • May 2008
                      • 482
                      On the right track. It is light infiltration akin to the old Ricoh Aficio 1045 when we had to pull the entire scanner up because of poorly designed support for the scanner/df assy.
                      "Enjoy every sandwich."
                      -- Warren Zevon
