Mpc 3502 with SR 3090 finisher
  • BLADE
    former propeller tester
    • 478
    #16
    Re: Mpc 3502 with SR 3090 finisher
    ok that's interesting, don't think I heard anything unusual tho
    Originally posted by TonerMunkeh
    Yes you can. Latest revision is D5885300B.
    Thnx TM, it has that version
    • DRichard
      • May 2008
      • 482
      #17
      [QUOTE=BLADE;536250]ok that's interesting, don't think I heard anything unusual tho
      While not an EXACT description of a problem I recently saw, this may be applicable. I found I had "jamming" issues with two different SR3090 finishers known to work fine on their own copiers. These newer series copiers needed finishers to have updated firmware to interface properly or they would stop as the paper exited the bridge. The SR3090 finishers required an updated NVRAM to be replaced in order to operate with the latest copiers. However, if you attached one of the larger finishers you could update (finisher) firmware through an SD card and it remedied the issue. Worth investigating? Good luck.
      "Enjoy every sandwich."
      -- Warren Zevon
      • Counsel
        • Aug 2011
        • 529
        #18
        Actually the fay after my response i had the exact machine and finisher jamming, it randomly would attempt to 3 hole punch paper that wasnt sent as a punch job but only if running a booklet, about every 10th sheet in a booklet run the punch engaged and jammed the paper. I reformatted hdd and problem went away.
        • BLADE
          • 478
          #19
          well its not my imagination because I went to a 3002 for a print quality issue, I read the smc and there was 60 code 100s,
          Oh well, let it go. Thanks all
          • kannuki2
            • Feb 2012
            • 398
            #20
            I have ran into many of that issue
            easy fix, on the proof tray it has 4 white tension rollers, cleaned it up and increase the tension springs on those rollers and the issue should get resolve
            • Mark Bbb
              • Jun 2012
              • 1662
              #21
              Don't give up so quickly.
              Have you tried to unplug and plug back in every connector on the finisher main board, that can really be a solution!
              And what is the exact jam location on the smc data sheet? Is the paper late or is the exit sensor activated to long?
              • BLADE
                • 478
                #22
                did I just read that
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  #23
                  Blade:
                  I really must learn to first read it all very well and then react!!
                  Yesterday I came upon a weird problem witch might interest you from this point:
                  mp2851 jammed every time with 3 persons when they send a print (with others employees it worked fine); Citrix environment; when we reinstalled the printer on there PC's everything was ok.
                  Strange thing: it only jammed with word documents, not with notepath or printer test page...
                  Iis it jamming both with copy-ing AND printing?
