MP 7500 sc 101 only when copy exp. glass
  • francisco
    • Nov 2009
    • 168
    Hy
    I had change all parts in the scanner unit(lamp,cables,boards..)
    thanks
  • Imprestik
    • Aug 2012
    • 297
    Re: MP 7500 sc 101 only when copy exp. glass
    Did you put the exposure glass the correct way back in?
    I'm pretty sure the white reference is on the glass and not on the scale
    • davel
      • Oct 2011
      • 1104
      Was it like that before you replaced the parts.
      • francisco
        • Nov 2009
        • 168
        yes
        it begins to happen only sometimes (once or twice a day) now is more frequente
        printing no problema
        copy with adf no problema
        only copy from the glass
        • Polarbear
          • Feb 2012
          • 1070
          Have you checked that all the mirrors are securely clipped int their holders? And that they are all level in their holders?
          Press the GREEN button!!
          • francisco
            • Nov 2009
            • 168
            more than check!!
            • davel
              • Oct 2011
              • 1104
              if only in morning could it be condensation under glass check if optics heater is fitted and working.
