Mp 5002 loud noise when duplex
  • mrfuser
    • 1617
    Machine makes a loud buzzing sound when duplex. Simplex is fine. Don't see anything out of place.
    any ideas?
  • mrfuser
    • 1617
    Re: Mp 5002 loud noise when duplex
    Actually it also happens on Symplex as well
    • mrfuser
      • 1617
      Replaced fuser and noise gone. Still get random sc350 codes.
        • 37490
        SC 350 dirty ID sensor. Clean with a soft cloth dampened with water only.
        • mrfuser
          • 1617
          Where Is that located on this guy?
          • LNorris
            • Sep 2008
            • 645
            when you pull out the drum unit, in that cavity is a little pcb that hangs down to the left side of where the pcu was. clean that and then there is a row of eraser lamps on the back side, check that for toner coverage as well and clean that while you havethe pcu out.
            • mrfuser
              • 1617
              Thanks , got it. Now to Figure out why that other fuser was making such a rattling sound !
              • Iowatech
                Not a service manager
                • 3930
                Unless that machine has teflon bushings between the hot roller and its bearings, probably the hot roller needed some high temp grease where the bearings are installed.The inner race of the bearing and the roller can rotate at different speeds, causing all sorts of wrong sounds.
