MP C3500 Magenta drum problem
  • Butrus
    • Jan 2012
    • 115
    Dot on magenta drum apeared.I changed the drum..good for awhile...apeared again.
    Changed the whole unit with developer and everything...good for awhile...apeared again.
    Changed the drum again and whole transfer belt unit(on inspection the old one looked fine) ...good for awhile...apeared again.
    The dot is always visable on the drum...looks like mechanical defect...like little cut...
    Its always only on magenta drum...
    Any suggestions?
    THANX!!!
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MP C3500 Magenta drum problem
    Is the dot always in the same place when you replace the drum?
    Hit it.
    • Butrus
      • Jan 2012
      • 115
      No.
      Sometimes also multiple dots....
      • HitMan
        • Aug 2015
        • 170
        magenta drum chip
        Maybe check that the other units aren't spreading any dirt through the machine. Maybe vac out the drum units before magenta. Make sure there's nothing stuck on the magnetic roller in the development unit. Could be hard toner or even a staple?
        • TonerMunkeh
          Professional Moron
          • 3865
          With how it's blown out it looks like an arc mark. Are there any ITB related SC codes?
          Hit it.
          • HitMan
            • Aug 2015
            • 170
            I know you said you replaced the complete unit but what's the condition of the charge roller? Any marks on the roller also?
            • Butrus
              • Jan 2012
              • 115
              Charge roller is good,no damage
              No SC codes
              What is arc mark?
              • HitMan
                • Aug 2015
                • 170
                Ark would be from a charge wire but these machines have charge rollers.
                  • 37490
                  Have seen this frequently when using cheap toner. Use only Genuine Ricoh.
                  Also, toner density could be too high. If you are using Genuine Ricoh, make the adjustments in the attached file.Service Program (SP) Settings.pdf
                  • HitMan
                    • Aug 2015
                    • 170
                    Nightmare fault
                    What about the drive gears for the magenta pcu? The ones the pcu engages with. The white gears at the back of the machine next to the rj45 type connector for the pcu. Could it be that the recycling unit at the pcu cannot get rid of the toner?
                    • UCPrint
                      • Oct 2012
                      • 24
                      Does the mark on the drum rub off or is their a nick on the drum?
                      Did you replace the dev unit or just redev it? if you just re deved it then its possible to still have toner debris in the unit which will contaminate the charge roller.
                      • meldwo
                        • Feb 2012
                        • 36
                        Any suggestions?
                        THANX!!!
                        replace the PCU and toner
                        • Butrus
                          • Jan 2012
                          • 115
                          I replaced the PCU
                          The nick is on the drum...can not be whiped off
                          I also replaced the whole dev. unit,not yust developer...
                          Toner is the same for all...CMYK
                          I have problem only with M
                          • TonerMunkeh
                            Professional Moron
                            • 3865
                            Is the screw lock on the front of the PCU cover? Could it be possible it is missing, someone is deliberately taking the drum unit out and damaging it?
                            Hit it.
