Started out as an SC 370 error. Resolved the error but started having add toner issues. Found and repaired the wire harness that connects to toner bottle holder (was pinched and had exposed wires) and had issue with dv unit & toner supply assembly. Replaced both dv unit & supply assembly and unit worked for a few days. Now has 0% toner again and have even tried different bottles. Cheated door and toner bottle turns am thinking may have to replace actual wire harness. Thoughts?
* Device only has 275,000 but has been at location 3 years.
