Ricoh Mpc 5000 Enable LAN
  • devontug
    • Apr 2015
    • 99
    [Misc] Ricoh Mpc 5000 Enable LAN
    Can anyone help to enable my LAN on my Ricoh Mpc5000 as it was driven by a fiery controller?
    Fiery controller is now busted and I want to be able to send prints without the fiery controller. The necessary settings is needed in system sp.
  • davel
    • Oct 2011
    • 1104
    Re: Ricoh Mpc 5000 Enable LAN
    SP 5-895
    • devontug
      • Apr 2015
      • 99
      thats all i need to change ?
      please bare in mind that it had a fiery controller on it and configured as such...
      • davel
        • Oct 2011
        • 1104
        Use normal Ethernet port, use correct drive.
        • devontug
          • Apr 2015
          • 99
          I used the normal port I only have the orange light on the network port ... No green light and I can't ping the printer serious settings issue ... Need to know all the system sp that needs changing
          • Nikolay
            • Oct 2016
            • 16
            5-985-001 to 1
            5-898-001 to 0
            5-193-001 to 0
            • mikadonovan
              • May 2008
              • 2931
              If on this model you have a gigabite ethernet card installed, plug into that one. It should work even if the fiery is not connected. Change the sp's mentioned above. I had this problem on a fiery driven c7501. After I removed the fiery controller, the only ethernet port that would work was the one I added when installing the fiery.
              NEVER ASSUME ANYTHING
              • devontug
                • Apr 2015
                • 99
                Ok will try this
                • anothertech
                  • 1769
                  I'd be really surprised if you could print through the gigabit port, as far as I've been told it is only for Fiery.
                  • devontug
                    • Apr 2015
                    • 99
                    That's what I was told also... I just want this thing to be configured so I can print without the fiery
                    • francisco
                      • Nov 2009
                      • 168
                      Hy just do the oposite
                      • devontug
                        • Apr 2015
                        • 99
                        Still not working
                        And SP5898 I don't see that in the listing ... This thing is irritating
                          • 37489
                          Originally posted by devontug
                          Still not working
                          It is 5895.
