Richo 270 SC322 fault. (Aficio)
  • Makin-copies
    • Jul 2025
    [Dead] Richo 270 SC322 fault. (Aficio)
    Hey folks,
    I'm not a copier tech, but I do bring my tech skills from another field. So I should be handle what suggestions are thrown my way.
    I've got this copier, RICHO 270. It was reporting a paper feed issue. when making a copy it would pull paper from tray 1 or 2 but then shortly there after.
    I would have to open the side doors and pull the paper out.
    This machine was quite filthy with toner so I pulled it apart and cleaned everything has delicately and thoroughly as I could.
    I put it all back together, and now I've got this SC322 code.
    I checked, and everything appears to be back in place. I even tried...
    To reset this error try the code:
    "Clear Mode"+107+"Clear/Stop" hold for 5s.
    Turn ON and OFF the Main Switch.
    Any suggestions... I can load up pictures for viewing...
    Thanks,
  • Elmo
    • Feb 2010
    • 541
    Re: Richo 270 SC322 fault. (Aficio)
    SC322: Laser synchronization error
    -Definition- [B]
    I Used To Live To Fix Things Now i Fix Things To Live
    • Makin-copies
      I know... but I want to give it a try. I feel like I've caused this fault... and it s simple fix..
      That's the hope.
        • 37489
        Your best bet is to replace the machine. If you really want to try to fix it, you are going to need a new laser unit part number A2671900.
        • LANUN_81
          • Jan 2017
          • 12
          do pm me if you want used laser unit
          • Mark Bbb
            • Jun 2012
            • 1662
            Let us pray for another printer gone to the forever printing fields...
            • copyaction
              • Oct 2007
              • 991
              Its been a while but I believe faulty door interlock switches also caused the code on this model.
