mpc6502 sc410-04
  • slot
    • Jul 2008
    • 341
    mpc6502 sc410-04
    we have an mpc6502 with loads of sc410 -04 we have changed the yellow dev but the sc still comes up I suspect its the drum as they have 1.2 m copies on them and the drum life is 900k is this a common fault as these drums get older as the service manule says its Residual Voltage (Vr) Detection Error (Y) but change the dev or its condensation any pointers please.
  • gkalman2004
    • 157
    Re: mpc6502 sc410-04
    Engine firmware
    read rtb attachement from http://www.copytechnet.com/forums/ri...670-sc819.html
    • slot
      • Jul 2008
      • 341
      thanks for your reply I will check the firmware
      • HitMan
        • Aug 2015
        • 170
        Tried the potential sensor that sits above the drum?
        • davel
          • Oct 2011
          • 1104
          If the drums are 300K over life change them, residual voltage is high on a worn out drum.
