It sounds like it's from the fuser but it all looks good mechanically. Doesn't always do it. I was going to replace the fuser only to find out that they're in excess of $1200. Anything common out there? I appreciate any help
Savin C9120 Grinding
Re: Savin C9120 Grinding
Here's one from a few years ago, that's was resurrected just a couple days ago:
if you pull the unit apart i would take a big piece of cardboard and make notes on it as you remove screws.
as far as 1200 for a fuser i would just buy a parts machine local with super low meter if the fuser is just toast...
if you need where to find just drop me an email.Comment
Sent from my iPhone using TapatalkComment
SP1-121-001 ([Switch:Rotation Start/Stop] Time:After Reload) [100] →[0]
SP1-121-002 ([Switch:Rotation Start/Stop] Time:After Recovery) [10] →[0]
SP1-121-003 ([Switch:Rotation Start/Stop] Time:After Job) [10] →[0]
i have a bunch of these and the previous series mpc2050/mpc2550 and they work well in the less than 5k/month enviroment..
I am happy when i get a chargeable fuser rebuild call,now if its on contract i wld pop in a parts unit and do the same
wth transfer belt and drums..it makes it worth the cost to store a low meter parts machineComment
and that is why you want to change these settings. And this has stopped the noise on all but 1 of this series that I have tried:
