AF 1060 A3 counter problems
  • Icopy
    I have 8 AF1060 and 5 AF1075 and a problem with 3 AF1060.
    Those 3 maschines havent the option to make A3 paper counting register as 1 instead of 2 on counter. There isnt an option in sp mode (it just isnt there) but on the rest of maschines it was normal, just switched the sp code and it worked. Any thoughts?
  • E Winter
    After entering the service mode, hold the # button and press "copy sp" - the double count sp should appear somewhere at the 5xxx SP modes then.
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      SP 5104
      • Icopy
        As i said, there just isnt the sp 5104 in SP mode. It goes like 5046 and the next one is 5106. What could it be? Software problem?
        • cobiray
          • Mar 2008
          • 1199
          Did you enter special service mode like Jan stated? It only shows up if you press the "#" key while entering tech mode.
          • Icopy
            Yes, found it, tnx a lot. I overlooked the hold # i kinda just pressed it...
