AF-3310L FAX
  • T911
    • Jun 2007
    • 628
    AF-3310L FAX
    sending and receiving is ok but when i go to make a (1) copy through the adf it jams. i will scan the original it will start to feed and stop 3 inches past the fuser with no image. i looked into the flag and sensors of the tray and adf but why doesn't it jam when receiving, only copying. scan lamp comes on and goes through the whole routine. i beleive it's a timing thing any ideas appreciated. thanks t
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Have the feed components been replaced? Does it do the same thing when faxing at a higher resolution? The copying should be a 300x300 dpi and the default fax resolution is 100x100 dpi (I think), so the feed speed is different. Does the original feed through or does it stop? If it stops check the sensor nearest to the lead edge for failure/flakiness/wear.
    • T911
      • Jun 2007
      • 628
      feed tires have not been replaced. didn't check the resolution for speed and the original feeds through. thanks t
