Large void band on Ricoh MPC6502
  • kannuki2
    • Feb 2012
    • 398
    Mpc6502 large void band at trail edge.
    I have enclosed an image for viewing. The image happened before fuser. I've replaced itb cleaning unit and still no improvement.IMG_2215.jpg
  • solorajder
    • Jul 2010
    • 106
    Re: Large void band on Ricoh MPC6502
    Is this a thick paper?
    Sent from my GT-I9195I using Tapatalk
    • kannuki2
      • Feb 2012
      • 398
      All regular 20lb paper
      • MIKON
        • Jul 2015
        • 187
        It appears to occur with all color's I would check transfer roller D1366240..........
        • Imprestik
          • Aug 2012
          • 297
          So have you pulled the transfer unit apart and had a look.
          My bet you be the large metal case that sits under the transfer unit on a angle has a seal on the end of it.
          That seal has either come off or warped causing this.
          Used to happen a lot of the ProC901
          • Polarbear
            • Feb 2012
            • 1070
            +1
            the pattern looks the same on both colours. It has to be related to the ITB. 2 colours cannot make exactly the same void pattern.
            Press the GREEN button!!
            • kannuki2
              • Feb 2012
              • 398
              I forget to include the yellow and black images. It is doing on all 4 colors. I did pulled the itb apart last Friday and could not see any out of ordinary but I will recheck it again. Thank you impretik, polarbear, and Mikon and everyone for the advice. I will go back there today and recheck the itb as recommended.
              • solorajder
                • Jul 2010
                • 106
                Try with another fuser unit
                  • 37490
                  If you don't see anything in the ITB,check the PTR.
