I have a Ricoh 2025 that had a flaky touch screen, I replaced touch screen and it will not respond at all. I tried the screen adjustment procedure ( 1993, c/s 5 times) when I touch the screen nothing happens. Has anyone experienced this problem? All feedback is appreciated.
ricoh 3025 touch screen problem
Tags: None
Re: ricoh 3025 touch screen problem
You either have not secured the ribbon cable properly, OR damaged the adhesive where it attaches to the screen while you were working on it -
Or he put the touch screen in upside down. Have made that mistake before...makes you talk nicely to yourself.Comment
