reset toner chip
  • islam90kh
    • May 2017
    • 7
    reset toner chip
    hello
    how i can reset toner chip for Ricoh Aficio SPC242SF ??
    Becouse i Cant find it to buy new in my country
  • copier tech
    • 8144
    Re: reset toner chip
    Why would you need to? when the toner says empty simply fit a new one, they come with chips!?
    • islam90kh
      • May 2017
      • 7
      Toner is full but the problem in the chip need to change but i cant find it in my country
      • copier tech
        • 8144
        Send the toner back to your supplier it is clearly faulty
        • islam90kh
          • May 2017
          • 7
          do you know any SP MODE TO disable chip ?
            • 37490
            Pixel count and AIO rotation distance use for computing toner end/near end are stored on the AIO itself. Only way to replace the chip is to replace the AIO.
            • PCC.TONER
              • Mar 2017
              • 13
              hello
              Hello
              if you still need to buy new chips , it is toner chip supplier from here: Toner chip, Copier parts, Toner Cartridge - einmay toner
              hope can help you.
              Linda
