Lower entrance guide plate ???
  • aalex_bom
    • Jan 2008
    • 214
    Lower entrance guide plate on fuser
    1,2,3 on pic , it is screw location, What is its effect!
    • 37489
    Re: Lower entrance guide plate ???
    Used to change the alignment of the lead edge of the paper to the hot/pressure rollers. Can be used for thin paper, to move the entrance guide to the left. This setting allows more direct access to the gap between the hot and pressure rollers, and prevents thin paper from buckling against the hot roller which can cause blurring at the leading edge of the copy. (taken from the Aficio 1035/1045 service manual)
    • aalex_bom
      • Jan 2008
      • 214
      can it reduce jam paper when he use thin paper? screw 1 or screw 3 , Is it better than for thin paper?
      he is MPC 6501,i think to use screw 3 for thin paper!!!
        • 37489
        If it not in the service manual or trouble shooting guide then trial and error.
