Scan to email on mp3351
  • mdfurqan2012
    • 194
    Re: Scan to email on mp3351
    Very simple, MP 3252 supports SMTP over SSL MP 3351 is an older model and does not. To use yahoo, turn on support for less secure sign in, see my previous post.
    As for your company SMTP, you may have to contact the support team for who ever provides the email service and find out what needs to be done to set up a non SSL relay server.
    Using yahoo smtp on mp2352 with less secure sign in.
    Kindly guide me if smtp connection test successful with smtp authentication is on by both yahoo and company's smtp then why transmission failed what settings i have to check. Kindly guide me what i miss?
    If mp3351 dose not support smtp over ssl then why company's own smtp on port 25 without ssl do not resolve issue kindly guide me what i am missing?
      • 37490
      MP 2352 does not require Yahoo less secure sign in. It has SMTP over SSL capability.
      Connection test only checks network connection. Will only fail if gateway, DNS, URL for SMTP server is not valid, or selected port is not available.
      Most likely company's SMTP requires at least SSL and probably TLS. If it is a local Microsoft exchange server, contact Microsoft for support. If it is an Office 365 cloud server, there are a number of threads in connectivity on how to do it, or you can Google it. If it is a service provided by your ISP, contact their business support group.
