aficio 2035 problem
  • gkalman2004
    • 157
    aficio 2035 problem
    Hi
    I have an old machine with printing problem i changed the development unit, the developer, id-sensor, charge roller, cleaning blade, secondary charge roller cleaning blade, i do id senzor init, td sensor init but still i have dirty page it is like raining with powder.
    Can be the Collection Coil:Ass'y fault ??
    1.
    20170619105459689.pdf
    2.
  • laitang
    • Nov 2012
    • 627
    Re: aficio 2035 problem
    Replace collection coil seal (AA15 0671)
      • 37489
      The spots on the drum is frequently caused by the use of third party drum, toner and developer. The lines on the drum indicate that the drum and cleaning blade need to be replaced.
      • gkalman2004
        • 157
        Thank's
        The cleaning blade was replaced already and i don't want to put new drum until i don't find why i have toner powder everywhere i will change first
        AA15 0671 Shield - Collection Coil and B082 2288 Collection Coil:Ass'y
        like said laitang because i already think about this posibility.
        If everything will be ok i will change also the drum .
        Also the toner powder is original and the development powder was changed by me with original one.
        • etsmultan
          • Apr 2007
          • 131
          Developer not intialize please intialize developer
          2.
          IMG_20170619_112629.jpg[/QUOTE]
          • solorajder
            • Jul 2010
            • 106
            If you have old warn pcu then the pcu is a problem
            Sent from my GT-I9195I using Tapatalk
            • FrohnB
              • Jul 2017
              • 1919
              Did you clean out the transfer unit that contacts the drum when the door is closed? That transfer unit holds onto all of the Waste Toner, and if it gets packed with spent toner or the cleaning blade for the transfer unit gets worn, then you can get weird spots like that. Remove the whole transfer unit (brown lever on operator side unlocks it) Take the brown transfer belt assembly out of the transfer unit (2 springs hold it down), and then take the cover with 6 screws off and vacuum out the waste toner. It also looks like the transfer blade may need replaced. I also agree that the Drum needs to come out and be replaced. Any time I change the blade I also change the drum. When you replace developer did you Initialize with SP 2-508?? when you replaced the drum cleaning blade, did you vacuum out the "Recycled toner" in the drum unit? I have had that recycled toner (on some of my first calls) fall down onto the drum and charge roller when reassembling, causing spots.
              Omertà
