MPC 3002 SC 101
  • Mark Bbb
    • Jun 2012
    • 1662
    #16
    Re: MPC 3002 SC 101
    Originally posted by gestetner tech
    Hi
    how do you mean that the fuser could affect the sc101?
    I know it said time to change fuser but that was 60k before the PM so i just reset the counter
    But i realy dont know how the fuser could be involved.
    Lars
    I have read it somewhere on this forum that the F.U. could provoke such matters...
    Is the mfp standing in a good ventilated place or not?
    It could be that the fusing unit is heating up that much that the scanner is getting "overheated". Is the scanner cavity (very) warm just after this code pop's up?
    • gestetner tech
      • Nov 2009
      • 45
      #17
      Re: MPC 3002 SC 101
      I could buy that if it was only during copy but it happens when they scan to email , so fuser are on rest temp.
      Thanks Lars
      • Mark Bbb
        • Jun 2012
        • 1662
        #18
        Re: MPC 3002 SC 101
        1. Check and clean the scanner mirror(s) and scanner lens.
        2. Check and clean the shading plate.
        3. Replace the exposure lamp.
        4. Replace the LED relay board.
        5. Replace the scanner mirror(s) or scanner lens.
        If heat is not the issue (which was in my case) than the above guide will help you further on.
        Good luck!
        • gestetner tech
          • Nov 2009
          • 45
          #19
          Re: MPC 3002 SC 101
          Good luck!
          Check my first post already done all that. + IPU board still the same.
          • Bantams
            • Jun 2012
            • 603
            #20
            Re: MPC 3002 SC 101
            Did you resolve this I have one doing the same randomly when scanning mostly
            • AUWI
              • Jan 2018
              • 7
              #21
              Re: MPC 3002 SC 101
              Hello everybody,
              i am from Germany does the machine also have a sc121?
              There is a problem with the ground at the ITB or at the PTR Roller in this series
