Ricoh MP c3002 poor print quality
  • StephenB
    • Aug 2015
    • 244
    Have an MP C3002, poor photo print quality. Copy quality great, internal test prints great, When I perform an ACC copier prints great. Then perform printer ACC, I get that funky (600 x 600) auto calibration test pattern.
    Saw a previous thread when clearing printer memory SP 5801-08 , then doing ACC ,the printout is perfect. And prints from the computer are perfect ! However if I scan in the auto calibration test pattern in when performing
    the ACC ( printer) everything goes back to crappy photo prints. If I Clear printer memory (SP 5801-08) again, and perform the ACC , printer without scanning in the test pattern, everything is great.
    I could probably leave it this way, but I want to solve this the right way, Any ideas ?
  • HitMan
    • Aug 2015
    • 170
    Are the optics spotless? Iv had an issue before with pcq after calibrating because of a lair of slight dust. Cleaned and calibrated was ok after
    • StephenB
      • Aug 2015
      • 244
      Re: Ricoh MP c3002 poor print quality
      yes, optics and laser lens cleaned.
      • StephenB
        • Aug 2015
        • 244
        Also switched print controller. But transferred the dimm and HDD to different controller pcb. Problem followed to different print controller.
        • StephenB
          • Aug 2015
          • 244
          Just tried the ACC using 1200 x 1200, scanned the test print and everything is prints good . However when performing the ACC using 600 x 600 and scan the test print, back to poor quality. What am I missing ?
          I could just make a note for this particular 3002, but it would be nice to have it right
            • 37547
            One thing to remember is that that most monitors are RGB where as color laser copier/printers are CMYK. The printed color is not going to exactly match what is on the screen. Also most monitors are light sourcing where copies are light reflecting/absorbing. Copies/prints are also effected by the color, quality, texture and thickness of the paper. I recently read a post about a customer who was printing on yellow paper and then asking why what was supposed to be white wasn't.
            When running ACC, I always clean the optics first. I then run copy ACC to set the scanning before running print ACC. Then run all print ACC in the order of lowest resolution to highest.
            • Gamut
              • Jul 2008
              • 216
              "If I Clear printer memory (SP 5801-08) again, and perform the ACC , printer without scanning in the test pattern, everything is great.
              I could probably leave it this way, but I want to solve this the right way, Any ideas ?"
              Vaguely recall this being an Eprom on I think the BCU or IPU.
              It has been covered on here before.
              • Tonerbomb
                AutoMajical Resolutionist
                • Feb 2005
                • 2589
                Try sp 5610-04, this will set ACC data back to factory settings, then do ACC. Sometimes the ACC data gets corupted from writing over itself so many times.
                Mystic Crystal Revelations
                • vga_man
                  • 78
                  Try to do force line adj. Mode c,a and b
                  2 times then restart from sp mode,
                  Calibrate colors from 123 menu,
                  Then replay the result :-)
                  • copier tech
                    • 8185
                    Check what levels your firmware is on, this often gets overlooked on these older models.
                    • StephenB
                      • Aug 2015
                      • 244
                      Want to thank everyone for all the input. I left the system performing an ACC on the 1200 dpi and so far everything is great.
