MP7000 sc547
  • digicor
    • Jul 2008
    • 1152
    MP7000 sc547
    I have replaced the thrmisters, with the newer parts #s, this machine ran for 6 months no problems, 5000/10000 sheets per month
    all of a sudden i get the 547 out of the blue? I changed the thermisters again just now, its not going away, im thnking the PWS?
    I un plugged the machine for a little bit, still same code, even with the door open and the fuser pulled out?
    what can it be? and is it fixable with out sending the machine to the big dumpster in the recycle sky?
  • solorajder
    • Jul 2010
    • 106
    Re: MP7000 sc547
    Did you reset SC code?
    Sent from my GT-I9195I using Tapatalk
      • 36906
      Re: MP7000 sc547
      SC 547 is a zero cross error. Either zero cross detection on the power supply or very trashy AC line voltage. If AC power is solar only, that could be the problem as solar may not be a true sine wave. Unless properly filtered, it is usually a stepped square wave which does not play nice with zero cross circuits as there is no actual zero cross.
      • Xcelsior
        Ex-Tech
        • Jan 2017
        • 24
        Re: MP7000 sc547
        As Slime mentioned, check the power supply or power line.
        The other thing is to make sure the thermistor wires aren't pinched/damaged. If the metal bracket pinches one too tightly and gets through the sheath it can cause Zero-Cross errors.
        Makes sure the wires are in good shape then enter SP mode, door open, reset machine. If it won't clear, start checking the power for noise.
        Previous Ricoh Field Service Tech II - November 2017.
        • MIKON
          • Jul 2015
          • 185
          Re: MP7000 sc547
          Check the heat lamp connectors make sure the blue connector is connected to blue terminal and green is connected to green terminal.
