Ricoh Aficio 401
  • Fierhawk
    • Jul 2025
    Ricoh Aficio 401
    What would cause me to have to put the pressure of the fuser section on the highest setting in order to get good fixing after I just replaced the pressure roller? Any help appreciated, thank you.
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    The only thing that comes to mind is the teflon bushing of the fuser roller that fits into the bearings.
    • Fierhawk
      • Jul 2025
      Thanks for the help. I have one other problem I need help with. The back of the copy gets a shadow, which from my experience comes from a dirty transfer belt. I have replaced the blade thinking the blade just wasn't cleaning the belt, the problem initially went away but came back. So probably not even a month ago I replaced the belt and blade and once again the problem went away. I got called back out there for a different problem but noticed the shadow on the back of the copy. So I was wondering what could be causing my problem?
