Today I did my first developer change on a MP2852 and I have a feeling something went wrong. After replacing it I went into the initialization and hit execute it didn't do anything and I seemed to have locked the screen some how. I couldn't exit or select anything on the screen so I shut off the copier and started it up again. I went back in and the 3XXX was grayed out so I couldn't do the initialization again. Any ideas of what I could have done? The copies were fine but I am afraid after a few thousand copies something might show up. Since I mostly do Canon and some Kyocera I haven't had to deal with developer for ages. It seems like dial up to me now.
Did I screw my developer change up?
Re: Did I screw my developer change up?
Sounds like the machine / software crashed on you.
A new pack of dev has the correct amount of toner in it.
It should of churned the dev for a minute or two until the TD sensor reached the optimal reference voltage value.
Once the machine adds toner or you do some printing it's pointless initializing dev as the reference reading would no longer be accurate and it may end up over or under toning as a result.
But on this particular model range it's not the end of the world.
If the print quality looks fine I'd say leave it alone.- Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Fully qualified technician for Ricoh - Canon - Sharp - HP - Brother - Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Dev initialization is, and always has been, SP2801 anyway, so I'm not sure what you were trying to setLast edited by sandmanmac; 10-27-2017, 03:44 AM.Comment
Yes use SP2801.
Maybe a print job was sent to the machine?
Always unplug network cable when working on any copier really.Let us eat, drink, and be merry, because tomorrow we may die!
​Comment
I am trying to do this from memory so I may have made a mistake in what I did or did not do. I thought I locked myself out of the 3xxx for some reason. Can someone tell me the wisdom of Ricoh not putting how to get into SP mode in the manual? It says ask your supervisor, which I think is the dumbest thing I ever heard in this business.Comment
Fully qualified technician for Ricoh - Canon - Sharp - HP - BrotherComment
With the 52s especially I've found that if you don't close the frond door once you are in SP mode and wait for the machine to warm up all the way and beep for readiness it will lock up like you described when you try to initialize the developer. If it happens just turn the machine off, open the front door again, and try again.Comment
Yeah general good practice is too unplug the network and fax cable, power up and wait a couple of minutes until it shows ready and any print engine movement has stopped.
I also still remove the toner and toner hopper until the dev initialization procedure is complete (like I said you don't want it adding any additional toner).- Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Do you really think if I had been to Ricoh training I would ask this question? Canon must have been crazy to tell us how to enter service mode while in class.Comment
