Toner pump rebuild?
  • mrfuser
    • 1617
    Toner pump rebuild?
    We have a bunch of the mpc4500 series toner pumps in the shop. Does anyone know if they can be rebuilt?
  • Coptech
    worker drone
    • 460
    Re: Toner pump rebuild?
    If you look at the bulletin, they re-designed the auger system. (bad engineering out of the gate) I would say it would be a waste of time trying to rebuild them.
    • fshead
      • 2376
      I HAVE rebuilt 8 of them
      • mrfuser
        • 1617
        How do you rebuild?
        • vga_man
          • 78
          If coluch works, so you can order a new pump rubber and open pump carefully then replace rubber ...
          But as they said " it's wasting your time "
          • Coptech
            worker drone
            • 460
            So who is selling the internal parts for the pumps?
            • fshead
              • 2376
              to each his own when having to shell at over $100 for a new one I ve spent an hour pulling them apart and changing the rubber pump..
              so far one failure abd i will pull that one apart and see if i missed something
                • 37490
                And what is your billable rate for an hour of time?
                  if his boss is like mine... " doesn't matter you're getting paid "
                  • mrfuser
                    • 1617
                    Thanks for all the talk BUT WHO sells the parts to rebuild?
                    • fshead
                      • 2376
                      Its really about is I like to take things apart and i work as an independant over 28years now.I dont
                      like the disposable mindset that techs i worked with before going solo all seem to follow,except a few.
                      What Ricoh gets to charge, like that small metal shaft piece you need when you do the transfer roller cases on the mpc3501 is crazy ...
                      I bought one and will make a few with my grinder,stone and tools in my workshop..even the metal plate i am making too..
                      the biggest issue i had with these pumps was taking them apart without breaking any tabs..but that i now have all figured out..
                      • vga_man
                        • 78
                        Order it from AliExpress Mobile - Global Online Shopping for Apparel, Phones, Computers, Electronics, Fashion and more
                        More some information about Egypt 🙂😀
                        Imported ricoh mpc5000 costs 120 USD, it's like a new pump from Germany)
                        • Coptech
                          worker drone
                          • 460
                          Just checked the dealer pricing and it is just over half of what you listed.
                          • fshead
                            • 2376
                            im not a dealer so i cant control what a dealer gets/...
                            i was under the impression he was marking up only 15%
                              • 37490
                              Thanks for the laugh.
