MPC4504ex - DF3090 Intermittently Jam P
  • Batman1976
    • Jun 2016
    • 91
    Hi Guys,
    Happy New year and all that!!
    Got a strange one on a new Ricoh Mpc4504ex - DF3090.
    When scanning double sided originals the ADF intermittently ejects the original without inverting the 2nd side thus causing a P Jam at the Document Feeder.
    Firmware is up to date. Has anyone seen this before?
    Cheers
    Batman1976
  • copier tech
    • 8144
    Re: MPC4504ex - DF3090 Intermittently Jam P
    Was this happening before you changed the contoller board!?
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      Strange one.
      Maybe compare a non-default SMC print out against the factory adjustment sheet since you recently changed the main controller.
      See if anything is a miss.
      Latest ARDF firmware is D7795300L (v1.330:03)
      • Batman1976
        • Jun 2016
        • 91
        Hi,
        Indeed it was happening before the controller was fitted. It appears there are 2 separate faults with the device.
        ADF FIRMWARE is on D7795300L(01.330:03)
        It is very intermittent, I have attended again and ADF was working fine, ran in ADF free run via service mode for 20 mins with no issues.
        HELP!!!
        • Elmo
          • Feb 2010
          • 541
          Sounds like the deflector plate is possibly sticking
          could be the foam noise reduction pad or the solenoid
          does it happen during a job
          or on the 1st page
          I Used To Live To Fix Things Now i Fix Things To Live
          • Batman1976
            • Jun 2016
            • 91
            or on the 1st page
            It either works or doesn't, I have monitored the solenoid while running the ADF and all seems fine, they device is brand new.
            Fault is extremely intermittent.
            Might get Ricoh in as had a lot of issues with device from new.
            • TonerMunkeh
              Professional Moron
              • 3865
              Skew correction sensor is lazy. I've had two do it, swap it with the registration sensor to test.
              Hit it.
