Ricoh 3045, User Tools lockout
  • callmefirst
    • Feb 2012
    • 51
    I am working on a Ricoh 3045 and I wanted to change some settings in user tools, the message I got was "you do not have privileges to use this function" , all I wanted to do was to change copier output to internal tray. I have never seen this message, where can I go the service mode to change this, I have looked in the service manual and I have not found the setting to change. Any help would be appreciated.
    • 30217
    Re: Ricoh 3045, User Tools lockout
    First try hard power reset and see if you still have issue.
    • cadillac2
      • Oct 2015
      • 42
      have you tried login in thru the WIM?
        • 37489
        You may need to be logged in as the proper Administrator.
        • mikadonovan
          • May 2008
          • 2931
          Turn off authentication in user tools>system settings>administrator tab
          NEVER ASSUME ANYTHING
          • hossam
            • Aug 2010
            • 70
            Login as supervisor and password=password, then Turn off authentication in user tools>system settings>administrator tab
              • 37489
              Only if someone has changed the supervisor password to password.
              • hossam
                • Aug 2010
                • 70
                i can't remember it!
                maybe it's = blank, right?
                • hossam
                  • Aug 2010
                  • 70
                  BTW
                  i'm just trying to help!
