MP2501
  • Gab
    • Aug 2015
    • 671
    MP2501
    maCHINE has abou 32k copies. In the past i had replaced developer due to dark background.
    Perhaps it was the toner .
    Now machine print a black line at the middle and dark background. I used geniuin toner and replaced drum and blade. Not Genuin drum.
    Now image is ok at the middle and light at both edges of a4 paper size. I executed sp 2-802 and 2 -801 with no result.
    I plan to replace developer too but i am sceptic because thw same i had thw same problem (image ok in the middle and light at edges ) and then i replaced Developer , drum (genuin) and problem remained. also i swaped a whole drum unit from an other machine for testing with no result.
    Is this machine so toner sensitive? Not genuin drum (i have used it in af 1022 and 1015 with no problems) causes such problems? Does some values change and couses this problem and these values remains and after dev and drum replacement?
    I already have replaced drum and i am afraid if i replace dev too the problem will remain.
    i.e About the other machine ia have some posts in the past.
  • fshead
    • 2376
    Re: MP2501
    it pretty easy to troubleshoot these problems,make a copy and stop it midcycle,pull drum and check..
    you might have "crud" in developer and if you want to
    spend time you could empty all developer unto a clean newspaper and check..
      Re: MP2501
      you mention all the work on drum and dev unit... did you clean all laser / trans sections?
      what did your voltage readings show?
      • fbkhan3
        • May 2012
        • 421
        Re: MP2501
        If you could mention the Developer type(Part Number) because developer and Toner used in this series of Machines are different then previous Models.
        Regard's
        • barratec
          • Jun 2008
          • 162
          Re: MP2501
          Check laser unit!
          • Gab
            • Aug 2015
            • 671
            Re: MP2501
            Regard's
            Developer is the right one . I know that developer in this machine is different thah those in af 2018 and af 2000
            • Gab
              • Aug 2015
              • 671
              Re: MP2501
              Originally posted by barratec
              Check laser unit!
              It is almost impossible to be laser unit. As i tald you before i replace drum , image was with dark background . I just replaced opc drum and blade and used geniuin toner istand of compatible . And after those replacements image is light at the edges.
                • 37481
                Re: MP2501
                If you do not use the correct toner for the developer being used, the machine will make good copies immediately after replacing the developer. As the incorrect toner is added to the developer, the quality goes to crap. So if you are trying to save money by purchasing cheap drums, developer and toner, you are wasting money in the long run.
                • fshead
                  • 2376
                  Re: MP2501
                  look considering you had probably a slight dumping of toner before this i would
                  clean everything where toner would drop including laser unit..
                  if it s spotless when you pull it then just drop it back in......
                  when i was a product specialist i f..kng hated going to CQ callbacks and find the tech never cleaned optics or interior of machine..MCP
                  • sandmanmac
                    • 3981
                    Re: MP2501
                    Agreed. There's no mention of cleaning the laser shield glass which is the likely cause at this point
                    • tufbnme
                      • 493
                      Re: MP2501
                      Check the charge roller.
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Re: MP2501
                        i have had several high level lessons "English language" and i practice it almost every day...
                        So, I know that the words are English, but what are they trying to say?
                        Is this a language speaken in space? Or when eaten space cake?
                        • patrickjlc
                          • Feb 2015
                          • 225
                          Re: MP2501
                          Check transfer roller/ unit.
                          Sent from my SM-G930V using Tapatalk
                          • sandmanmac
                            • 3981
                            Re: MP2501
                            I'd love to hear your explanation for why replacing a drum would have ANYTHING to do with what could easily (and probably is) dirty laser optics.
                            You see....what likely happend is all that crappy toner was blowing around inside the machine and dusted the shield glass, and possibly more, but you go ahead and argue with everyone, and don't bother even checking!
                            • barratec
                              • Jun 2008
                              • 162
                              Re: MP2501
                              You are right! dark background(caused by developer) and blowing toner on the laser unit are typical in MP2501 machines!
