Ricoh FAX 3320L
  • mansart
    • 852
    [Misc] Ricoh FAX 3320L
    Can anyone please tell me how to disable ECM on a Ricoh FAX 3320L?
    Thank you.
    • 37489
    Re: Ricoh FAX 3320L
    Probably in FAX SP bit switches. You need to use your service manual and write down what you have changed. Better yet, if you are a tech with an authorized Ricoh dealer, call or text the tech support hotline and they will walk you through it.
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      Re: Ricoh FAX 3320L
      PM sent.
      I'll walk you through it.
