Disable Copy/Scanning from flatbet
  • miloy7
    • Jan 2017
    • 12
    [Misc] Disable Copy/Scanning from flatbet
    Is there a way to disable these function and make it to dedicated printing? I have mp4001 device and the scanning IO board was damaged and find it hard to buy in our country (Philippines). Need help. thank you!
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 589
    Re: Disable Copy/Scanning from flatbet
    SP 5118 is named disable copying. But it also says Japan only. So your mileage may vary. It might also lock them out completely from using the control panel. I've never tested it.
    5118* Disable Copying
    Temporarily denies access to the machine. Japan Only
    [0 to 1 / 0 / 1]
    0: Release for normal operation [Default]
    1: Prohibit access to machine
    • sandmanmac
      • 3951
      Interesting....
      He could also consider simply enabling user authentication for the Copy/scanner functions
