Sc370-01 mpc6502
  • ReyTech
    • Aug 2016
    • 8
    [Error Code] Sc370-01 mpc6502
    Hi! Anyone encounter this error code sc370-01 mpc6502. ITB unit and transfer belt are new. Thank you in advance.
  • cadillac2
    • Oct 2015
    • 42
    Re: Sc370-01 mpc6502
    clean the id sensors
    • aktasson
      • Feb 2017
      • 201
      Just found sc370-02 with a ID sensor and firmware problem.
      Gesendet von meinem G8141 mit Tapatalk
      • Imprestik
        • Aug 2012
        • 291
        Did you put the transfer belt on correctly with the encoder on the correct side?
        • ReyTech
          • Aug 2016
          • 8
          Thank you for the reply, it was sorted out. I replaced the id sensor.
