Ricoh MP C4000 - Scan to Folder issue
    • 30247
    #16
    Re: Ricoh MP C4000 - Scan to Folder issue
    Another option if machine is to old to support firmware update to smb 2 or 3 would be to replace machine with a new model.
    • esabet
      • Apr 2018
      • 8
      #17
      Originally posted by mincopier
      Don't worry so much about what version, just upgrade to the latest version of firmware.
      On a Ricoh device just go into System settings, Network tab, Print List. Look under the SMB section and look for a line that has Client V3.
      I have printed the list and I am failing to locate the SMB Client version. Perhaps I am missing something. I have attached the print out for your kind review.MPC4000.Network Interface Settings.pdf
      • esabet
        • Apr 2018
        • 8
        #18
        Purchasing a new unit is not always a possibility for obvious reasons. Here is a snapshot of the current firmwares.
        • mikedci
          • Jul 2010
          • 227
          #19
          There is no SMBv2/v3 for this model. It's old enough they might not release any firmware for it as they just released smbv2/v3 firmware for the MPC4502/5502 machines...
          • esabet
            • Apr 2018
            • 8
            #20
            Interesting as i've never had to change this setting from default on multiple Win 10 installations.
            My laptop is set as following & scans via SMB fine.
            [ATTACH=CONFIG]39478[/ATTACH]
            Checked the other two PCs. The NetBios setting is set as default but I did notice that SMB v1 was in fact enabled on both other machines. This further confirms that the MPC4000 only supports SMB v1.
            • skinnyb
              • Jul 2008
              • 291
              #21
              Yes bingo.
              Sent from my VS987 using Tapatalk
